MAX-10 IBIS model issue
Thanks for your advice.
In my opinion, the difference between LVTTL and LVCMOS model is the voltage leveling difference, not meaning the difference on physical die. As you can change the output mode from LVTTL to LVCMOS in a specific GPIO pin through Quartus project, however, the structure of gate in the I/O bank has not been changed.
So, don't worry about they have different electric characteristic. The IBIS model just reflect the I-V curves under different situation.
BR,
Mengzhe
Hello Mengzhe,
I am using MAX10 IBIS model from that model- lvttl_rio_d4s2 in this model
the power clamp table exhibits stair-stepping .
According to IBIS specification ,There should be no stair stepping of any I-V tables, with flat sections and abrupt jumps. This is caused by
insufficient significant digits in the table current columns
can you please check attached snapshot below
shweta chendake
