9 years agoMAX 10 Flash programming
In MAX 10 FPGA, when the CFM will program ? What are the signals are related to flash ? CONFIG_SEL pin is used to select the CFM0 and CFM1 but, how the process will work ? Please explain if anyone knows. Thanks in advance. Regards, KVL11 Replies
A little bit of overview info here, in chapter 2: https://www.altera.com/literature/ug/ug_usb_blstr.pdf
There is very little public documentation around on what goes in the CPLD as far as features/functionality. However, the Altera JAM STAPL (https://www.altera.com/support/support-resources/download/programming/jam.html) player does/did support using the USB Byte Blaster in simple JTAG bit banging mode. From the header comments in the jamstub.c routine:
I have used this code as part of a custom JTAG scanner that employed the Altera USB Blaster as the hardware interface./* The following code doesn't fully utilize the possibilities of the * USB-Blaster. It only buffers data up to a maximum packet size of 2 bytes. * The normal maximum packet size is up to 64 bytes (but would require a * major change to the logic of this program). * * Actually, the USB-Blaster offers a byte-shift mode to transmit up to 504 data * bits (bidirectional) in a single USB packet. A header byte has to be sent as * the first byte in a packet with the following meaning: * * Bit 7 (0x80): Must be set to indicate byte-shift mode. * Bit 6 (0x40): If set, the USB-Blaster will also read data, not just write. * Bit 5..0: Define the number N of following bytes * * All N following bytes will then be clocked out serially on TDI. If Bit 6 was * set, it will afterwards return N bytes with TDO data read while clocking out * the TDI data. LSB of the first byte after the header byte will appear first on TDI. */ /* Simple bit banging mode: * * Bit 7 (0x80): Must be zero (see byte-shift mode above) * Bit 6 (0x40): If set, you will receive a byte indicating the state of TDO in return. * Bit 5 (0x20): Output Enable/LED. * Bit 4 (0x10): TDI Output. * Bit 3 (0x08): nCS Output (not used in JTAG mode). * Bit 2 (0x04): nCE Output (not used in JTAG mode). * Bit 1 (0x02): TMS Output. * Bit 0 (0x01): TCK Output. * * For transmitting a single data bit, you need to write two bytes. Up to 64 * bytes can be combined in a single USB packet. * It isn't possible to read a data without transmitting data. */
