9 years agoMAX 10 fails to run JTAG loaded SOF
I have run into an odd problem with a new board that has a Max 10 10M50SA FPGA on it. (Specifically, the 10M50SAE144) The JTAG port appears to work, I can auto-detect the FPGA correctly, and Qu...
GBalb2
7 years agoHi, did you find any solution about this problem?
I've found the same issue in my new board. The JTAG seems ok, but my 10M50SA144 doesn't start after the SOF loading. No warning, no error. The nStatus/nConfig/Conf_done have the right pullups.
The signal tap says "INVALID JTAG Configuration".
Thanks for any comment.
Gabriel
