9 years agoMAX 10 fails to run JTAG loaded SOF
I have run into an odd problem with a new board that has a Max 10 10M50SA FPGA on it. (Specifically, the 10M50SAE144) The JTAG port appears to work, I can auto-detect the FPGA correctly, and Qu...
9 years agoGenerally the MAX10 should work with SOFs in the current Environment. I only observe sometimes an issue when it comes to reprogramming: For some reason SignalTAP does not seem to load a freshly built file, after "programm" . I have to delete and reassign the file.
