8 years agoMAX 10: a clock for SPI
Is using an external clock without a clock buffer causing any problem? I'm implementing SPI slave. An external SPI clock is directly from a pin(not a clock pin, but just an IOpin) of the FPGA...
8 years agoYou have no timing constraints? What 'timing violations' are being reported?
What hardware are you using? Is the FPGA your a host talking to an external slave device? You mention a 50MHz clock. What hardware are you using? Assuming you are trying to talk to an external slave and you'd simply like to get something working I suggest you use the 50MHz clock to clock all your logic and treat your sclk as a signal (not a clock) that you generate with logic. You are going to need more of a state machine to implement an SPI host as well. JRL - whilst I agree this may not be ideally coded, the code does conform to the classic clock & (asynchronous) reset in the sensitivity list with a single conditional statement (if) handling the reset (in_CSn). So, I feel Quartus will have no trouble understanding this or timing it. Cheers, Alex
