15 years ago
matrix transpose code in vhdl
Dear all,
I want to transpose a set of matrix from row to column.I has write the code in VHDL but has error occured.Below is my code:
library ieee;
use ieee.std_logic_1164.all;
entity transpose is
port (
-- Inputs
in1 : IN integer RANGE -127 TO 127;
in2 : IN integer RANGE -127 TO 127;
in3 : IN integer RANGE -127 TO 127;
in4 : IN integer RANGE -127 TO 127;
in5 : IN integer RANGE -127 TO 127;
in6 : IN integer RANGE -127 TO 127;
in7 : IN integer RANGE -127 TO 127;
in8 : IN integer RANGE -127 TO 127;
--Outputs
out1 : OUT integer RANGE -127 TO 127;
out2 : OUT integer RANGE -127 TO 127;
out3 : OUT integer RANGE -127 TO 127;
out4 : OUT integer RANGE -127 TO 127;
out5 : OUT integer RANGE -127 TO 127;
out6 : OUT integer RANGE -127 TO 127;
out7 : OUT integer RANGE -127 TO 127;
out8 : OUT integer RANGE -127 TO 127);
end transpose;
architecture transpose of transpose is
begin
for i in 1 to m loop;
for j in 1 to n loop;
Gazouta (i,j)<= Gazinta (j,i);
end loop;
end loop;
end transpose;
Can anyone help me correct this code?Many thanks
    Given your lack of knowledge of VHDL, and your random copy/pasting of other bits of code, I suggest you find a beginners guide to VHDL and get reading. Copy/pasting code from posts on forums is not going to help you learn.
    I think you should define an array of integers type to represent a matrix and use that one as type for your inputs and outputs.
    Dear Daixiwen,
    Yes, i just notice that Gazota and Gazinta after i run the code and error occur because i not declare them.Actually i found the loop process (code) in this forum.Then i try to write the whole vhdl code.So, know i get a new error.Did you has any idea?
    Many thanks
    Dear Tricky,
    Thanks a lot for give response. I will write the code back.
    Many Thanks.
    process
    begin
        end loop;
      end loop;
    end process;
    Dear Tricky,
    I not familiar using loop operation.Can u give simple loop coding?
    Many thanks
