Matrix multiply algorithm
I'm trying to implement a systolic matrix multiplication algorithm and have written the following so far. Of particular interest is the PROCESS, which has a nested IF. When I compile, it says (expected "if" where PROCESS). All of the source I've written is below.
I don't understand why I would get that error when compiling. I ENDed both IFs correctly from what I see. The components are simple, I can post them if needed.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY lab2 IS
PORT (clk, rst: IN STD_LOGIC);
END lab2;
ARCHITECTURE structure OF lab2 IS
TYPE matrix_row IS ARRAY (6 downto 0) OF std_logic_vector(3 downto 0);
TYPE matrix_west IS ARRAY (0 to 3) OF matrix_row;
TYPE matrix_north IS ARRAY (0 to 3) OF matrix_row;
TYPE matrix_done IS ARRAY (0 to 3, 0 to 3) OF std_logic_vector(7 downto 0);
CONSTANT matrix_A: matrix_west :=((X"0",X"0",X"0",X"5",X"3",X"1",X"2"),
(X"0",X"0",X"2",X"3",X"1",X"2",X"0"),
(X"0",X"1",X"2",X"3",X"4",X"0",X"0"),
(X"3",X"2",X"4",X"1",X"0",X"0",X"0"));
CONSTANT matrix_B: matrix_north :=((X"1",X"1",X"3",X"2",X"0",X"0",X"0"),
(X"0",X"3",X"2",X"1",X"2",X"0",X"0"),
(X"0",X"0",X"2",X"1",X"3",X"1",X"0"),
(X"0",X"0",X"0",X"1",X"4",X"2",X"3"));
CONSTANT matrix_result: matrix_done :=((X"00",X"00",X"00",X"00"),
(X"00",X"00",X"00",X"00"));
PORT (west, north: IN std_logic_vector(3 downto 0);
south, east: OUT std_logic_vector(3 downto 0);
result: OUT std_logic_vector(7 downto 0));
END COMPONENT;
COMPONENT adder IS
PORT (new_term: IN std_logic_vector(7 downto 0);
stored: IN std_logic_vector(7 downto 0);
END COMPONENT;
SIGNAL west1, west2, west3, west4: std_logic_vector(3 downto 0);
SIGNAL north1, north2, north3, north4: std_logic_vector(3 downto 0);
SIGNAL w1_2, w2_3, w3_4, w5_6, w6_7, w7_8: std_logic_vector(3 downto 0);
SIGNAL w9_A, wA_B, wB_C, wD_E, wE_F, wF_0: std_logic_vector(3 downto 0);
SIGNAL n1_5, n2_6, n3_7, n4_8, n5_9, n6_A: std_logic_vector(3 downto 0);
SIGNAL n7_B, n8_C, n9_D, nA_E, nB_F, nC_0: std_logic_vector(3 downto 0);
SIGNAL result1, result2, result3, result4: std_logic_vector(7 downto 0);
SIGNAL result5, result6, result7, result8: std_logic_vector(7 downto 0);
SIGNAL result9, resultA, resultB, resultC: std_logic_vector(7 downto 0);
SIGNAL resultD, resultE, resultF, result0: std_logic_vector(7 downto 0);
SIGNAL store1, store2, store3, store4: std_logic_vector(7 downto 0);
SIGNAL store5, store6, store7, store8: std_logic_vector(7 downto 0);
SIGNAL store9, storeA, storeB, storeC: std_logic_vector(7 downto 0);
SIGNAL storeD, storeE, storeF, store0: std_logic_vector(7 downto 0);
SIGNAL return1, return2, return3, return4: std_logic_vector(7 downto 0);
SIGNAL return5, return6, return7, return8: std_logic_vector(7 downto 0);
SIGNAL return9, returnA, returnB, returnC: std_logic_vector(7 downto 0);
SIGNAL returnD, returnE, returnF, return0: std_logic_vector(7 downto 0);
BEGIN
X1: multiplier PORT MAP (west=>west1, north=>north1, south=>n1_5,
east=>w1_2, result=>result1);
X2: multiplier PORT MAP (west=>w1_2, north=>north2, south=>n2_6,
east=>w2_3, result=>result2);
X3: multiplier PORT MAP (west=>w2_3, north=>north3, south=>n3_7,
east=>w3_4, result=>result3);
X4: multiplier PORT MAP (west=>w3_4, north=>north4, south=>n4_8,
east=>OPEN, result=>result4);
X5: multiplier PORT MAP (west=>west2, north=>n1_5, south=>n5_9,
east=>w5_6, result=>result5);
X6: multiplier PORT MAP (west=>w5_6, north=>n2_6, south=>n6_A,
east=>w6_7, result=>result6);
X7: multiplier PORT MAP (west=>w6_7, north=>n3_7, south=>n7_B,
east=>w7_8, result=>result7);
X8: multiplier PORT MAP (west=>w7_8, north=>n4_8, south=>n8_C,
east=>OPEN, result=>result8);
X9: multiplier PORT MAP (west=>west3, north=>n5_9, south=>n9_D,
east=>w9_A, result=>result9);
XA: multiplier PORT MAP (west=>w9_A, north=>n6_A, south=>nA_E,
east=>wA_B, result=>resultA);
XB: multiplier PORT MAP (west=>wA_B, north=>n7_B, south=>nB_F,
east=>wB_C, result=>result;
XC: multiplier PORT MAP (west=>wB_C, north=>n8_C, south=>nC_0,
east=>OPEN, result=>resultC);
XD: multiplier PORT MAP (west=>west4, north=>n9_D, south=>OPEN,
east=>wD_E, result=>resultD);
XE: multiplier PORT MAP (west=>wD_E, north=>nA_E, south=>OPEN,
east=>wE_F, result=>resultE);
XF: multiplier PORT MAP (west=>wE_F, north=>nB_F, south=>OPEN,
east=>wF_0, result=>resultF);
X0: multiplier PORT MAP (west=>wF_0, north=>nC_0, south=>OPEN,
east=>OPEN, result=>result0);
Adder1: adder PORT MAP (new_term=>result1, stored=>return1,
result=>store1);
Adder2: adder PORT MAP (new_term=>result2, stored=>return2,
result=>store2);
Adder3: adder PORT MAP (new_term=>result3, stored=>return3,
result=>store3);
Adder4: adder PORT MAP (new_term=>result4, stored=>return4,
result=>store4);
Adder5: adder PORT MAP (new_term=>result5, stored=>return5,
result=>store5);
Adder6: adder PORT MAP (new_term=>result6, stored=>return6,
result=>store6);
Adder7: adder PORT MAP (new_term=>result7, stored=>return7,
result=>store7);
Adder8: adder PORT MAP (new_term=>result8, stored=>return8,
result=>store8);
Adder9: adder PORT MAP (new_term=>result9, stored=>return9,
result=>store9);
AdderA: adder PORT MAP (new_term=>resultA, stored=>returnA,
result=>storeA);
AdderB: adder PORT MAP (new_term=>resultB, stored=>returnB,
result=>store;
AdderC: adder PORT MAP (new_term=>resultC, stored=>returnC,
result=>storeC);
AdderD: adder PORT MAP (new_term=>resultD, stored=>returnD,
result=>storeD);
AdderE: adder PORT MAP (new_term=>resultE, stored=>returnE,
result=>storeE);
AdderF: adder PORT MAP (new_term=>resultF, stored=>returnF,
result=>storeF);
Adder0: adder PORT MAP (new_term=>result0, stored=>return0,
result=>store0);
PROCESS (clk,rst)
VARIABLE addr: INTEGER RANGE 0 TO 7;
BEGIN
addr := 0;
IF (addr < '7') THEN
IF (rst = '1') THEN
addr := 0;
ELSE IF (clk'EVENT AND clk = '1') THEN
west1 <= matrix_A(0)(addr);
west2 <= matrix_A(1)(addr);
west3 <= matrix_A(2)(addr);
west4 <= matrix_A(3)(addr);
north1 <= matrix_B(3)(addr);
north2 <= matrix_B(2)(addr);
north3 <= matrix_B(1)(addr);
north4 <= matrix_B(0)(addr);
addr := addr + 1;
END IF;
END IF;
END PROCESS;
END structure;
1 Reply
The error you're seeing is because you've opened 3 if statements but only closed 2, you can either change "else if" to "elsif" and keep 2 "end if" statements or add a 3rd "end if".
