11 years agoMatrix Multiplication optimization
Hello, I am using FPGA EP3C40Q240C8. I have written a code for Kalman filter in which I have to do matrix multiplication and matrix inverse. The problem is that there is no error in my code but Fitte...
11 years agoPipelining is the chain of registers that are inserted into your algorithm to reduce the logic between registers. It increases the latency, but massively increases the FMax. Latency is usually not important, it's the throughput that counts (and throughput increases with clock speed).
As for signals vs variables: signals are only updated when a process suspends - so in a clocked proecss every signal assignment will become a register. Variables are updated immediately, so the logic that is produces depends on the order of the assignments in the code. There is nothing you can do with variables that you cannot do with signals. And as variables can be more unpredictable, usings signals is far safer for a beginner. But, I highly recommend you take a step back. Do you have a drawing of how this algorithm will look on hardware? one that you drew before you wrote any code? HDL is a hardware description language - if you dont know what hardware you want, how do you expect to describe it?
