15 years agomatrix array in vhdl
Dear all, I have 4x4 matrix and I want to read this matrix row by row on each clock cycle. For example, row1 is read in cycle1, row2 is read in cycle2 and so on. Can anyone give idea how to w...
15 years agoThat's the problem when using abstract data types like integer. You can use them in hardware design, but you should know what you are doing. By default, integer is a signed 32 bit quantity, thus each integer array element is infered as signed(31 downto 0). It's easy to calculate the amount of port bits needed to represent the array.
To learn about reasonable usage of the integer type in hardware designs, you can review the Quartus VHDL binary counter template. Generally you need to constrain it by setting a range in the type definition. My personal opinion is, that you should better use signed or unsigned types for the top entitie's port. Altough the port is represented by a bit_vector, you can't access individual bits without type casting the signal, because integer abstracts from it. Somewhat confusing, I think. Integers are however appropriate for internal signals.
