14 years agoMatrix Adder
Hello, I have one captious question. I need to buil-up matrix adder. Totally 1920x1080=2073600 cells able to do three different operations with 24bit integer value: 1/ A+B=C 2/ A-B=C ...
14 years agoOuh, I am sorry, my mistake... 75. I repaired it yet. :eek::rolleyes::oops:
Frame rate is 30 frames per second. Bus clock is 75 Mhz. There is a small problem. I need to process at least 200 pictures per second independently on the basic frame rate from ccd camera. So, 4GHz would be better. :-P Is it possible to buy such one chip solution from Altera ?
