14 years agoMatrix Adder
Hello, I have one captious question. I need to buil-up matrix adder. Totally 1920x1080=2073600 cells able to do three different operations with 24bit integer value: 1/ A+B=C 2/ A-B=C ...
14 years agoHello,
yes I am looking for full HD real time parallel matrix processor slice with programmable cells function with 1920x1080 cells. Ideally, it should be able to work at 800 Mhz, 30 frames/sec. Input stream: Parallel data 32(24) bit bus, 2073600 transmissions for every frame, 75Mhz bus clock, asynchronous hi speed FIFO feeding to input latches in altera registers. Output stream: one 64 bt value - long integer. i.e. 30x64=1920bites per sec. That is all. I see, Altera provides no such PLA chip and number of cells on chip is extremly small for such purposes these days. Maybe 1000 yeas in time. I am wonder, no one need such extremly useful tool in the real world. Or have anyone of you any good idea how to do it ? Many thanks.
