9 years agoMarvell 88EE1111 PHY tranciever MDIO reg configuration
I'm trying to troubleshoot PHY for my dual Ethernet design on the DE2-115 Cyclone IV board. (I have to load my *.elf file twice for some reason for my design to work). In trying to figure ou...
9 years agoHello, I need some help.
I have an altera DE-115 which has two ethernet ports, all i want is to receive ethernet frame on ethernet port 1 and send that same frame from ethernet port 0. I can receive ethernet frame on fpga board from ethernet port 1 but cannot transmit that same frame from ethernet port 0. On both ports two different PC's are connected. What changes should i make in this code volatile int * tse = (int *) 0x00102000; Initialize the MAC address *(tse + 3) = 0x116E6001; *(tse + 4) = 0x00000F02; // Specify the addresses of the PHY devices to be accessed through MDIO interface *(tse + 0x0F) = 0x10; *(tse + 0x10) = 0x11; Write to register 20 of the PHY chip for Ethernet port 0 to set up line loopback *(tse + 0x94) = 0x4000; // Write to register 16 of the PHY chip for Ethernet port 1 to enable automatic crossover for all modes("| = OR") *(tse + 0xB0) = *(tse + 0xB0) | 0x0060; // Write to register 20 of the PHY chip for Ethernet port 2 to set up delay for input/output clk *(tse + 0xB4) = *(tse + 0xB4) | 0x0082; // Software reset the second PHY chip and wait *(tse + 0xA0) = *(tse + 0xA0) | 0x8000; while ( *(tse + 0xA0) & 0x8000 ) ; // Enable read and write transfers, gigabit Ethernet operation, and CRC forwarding *(tse + 2) = *(tse + 2) | 0x0000004B;
