9 years agoMarvell 88EE1111 PHY tranciever MDIO reg configuration
I'm trying to troubleshoot PHY for my dual Ethernet design on the DE2-115 Cyclone IV board. (I have to load my *.elf file twice for some reason for my design to work). In trying to figure ou...
9 years ago --- Quote Start --- Indeed - my mistake. I found only the product brief shipped with the kit. Going back to your original issue - does your code allow the Phy time to 'settle' before trying to configure it? By the time you re-load the elf it's been running for a number of seconds. Are you simply trying to do 'something' too early? Do you write to address 20 in your code? Comment it out if so. I doubt it's relevant. I remember not having to do any configuration to get the Phy working. Cheers, Alex --- Quote End --- Alex, i'm not sure why, but it seems MDIO register 20 for setting up the delay for the I/O clock for Gigabit DDIO seems necessary in my case. I tried removing the line, but transmission seems to stop. Only when it is enabled does the traffic resume.
