17 years agoMailboxes error in multicore system
Hi, I have a 2-CPU system based on the NEEK, with two mailboxes (one for each CPU). One CPU send a 4-bytes message to the other, which displays it. The problem is that after that, the send and get...
17 years agoHi,
Thanks for the quick reply. But I don't agree with your explanation, because each CPU are waiting 1 second (1000000 µs) before sending new message/checking new messages. So each second there must be a new message in the mailbox, and the other CPU should be able to read it, instead of getting: --- Quote Start --- fall asleep...and wake up...dans le while... check msg:-11 --- Quote End --- Thank you for your help!
