M9K utilization is different for the same RAM IP for two different projects.
Quartus Standard 18.1 is relatively old. Is it possible to try the latest Quartus Standard 25.1 and check if the issue persists?
Please archive the project before migrating to the newer Quartus version.
If the issue still occurs, could you share both project .QAR files so I can investigate further?
Richard Tan
Thank you for replying to my query!
Since, the project has a NIOS-II core I couldn't build it using Quartus 25.1 std. However, I did build the project using Quartus 23.1.1 std and the resource utilization numbers are still the same ( 18 M9k - Project 1, 32M9K - Project 2).
Due to confidentiality reasons I cannot share the .QAR files. Further, I tried inspecting the synthesis and fitter logs in detail. It was observed that the project 1 which consumes lower RAM blocks (18) has the following logs in its synthesis report:
Info (270021): Converted the following 4 logical RAM block slices to smaller depth
Info (270020): Converted the following logical RAM block "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ALTSYNCRAM" slices to smaller maximum block depth of 1024
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a5"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a4"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a1"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a0"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a3"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a2"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a15"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a14"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a11"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a13"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a16"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a12"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a21"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a30"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a29"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a28"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a27"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a26"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a25"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a10"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a24"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a9"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a23"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a8"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a22"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a7"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a6"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a20"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a19"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a18"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a17"
Info (270019): RAM block slice "QSYS:qsys_inst|QSYS_onchip_memory2_0:onchip_memory2_0|altsyncram:the_altsyncram|altsyncram_llc1:auto_generated|ram_block1a31"This particular entry is not present in the second project that consumes 32 M9K cells. Is this something that could be related to this issue ?
- Akhilesh S.
- RichardT_altera5 months ago
It could be possible, but I cannot confirm at this point.
Are the on‑chip memory configuration settings the same in both Project 1 and Project 2?
Are there any differences in the Analysis & Synthesis or Fitter settings?
Richard Tan
