8 years agoLVDS Signal DC offset and AC Swing
Hi, What is the value of LVDS DC offset and LVDS AC Swing of Cyclone 10 GX devices?
8 years agoWhy do you refer to Cyclone V GX instead of Cyclone 10 GX documents? The relevant are the transceiver PHY user guide https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-10/ug_cyclone10_xcvr_phy.pdf and the datasheet https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-10/c10gx-51002.pdf
However neither C5GX nor C10GX have programmable transceiver Vocm level. Datasheet specifies 0.65 V for C5GX and 0.4/0.5 V for C10GX. Setting transceiver Vocm to 1.25 V LVDS value is simply impossible due to the low transceiver supply voltage. You didn't yet answer the question about AC coupling option. What's your application?
