CHARLES_Antoine
5 years agoLVDS SERDES Transmitter / Receiver IP
I am trying to design a VHDL program with the ALTLVDS_RX and ALTLVDS_TX IPs. I can't find any example on your site, and the clocking system with the fractional PLL is giving me problems. I ...
- 5 years ago
Couple of things:
1) The ALTLVDS IP does not support single-ended I/O standard. So, the rx_in and tx_out pins should be assigned I/O standard as LVDS.
2) Next, when you assign it as LVDS, you need to insert an ALTIOBUF in differential mode for each of the IP.
CHARLES_Antoine
5 years agoI would just like to start by making these two IPs proposed by quartus work
