11 years agoLVDS SERDES doesn't work
I'm using Arria-10 to make a LVDS SERDES. But it doesn't work. Looking forward to your help.
The code is as below. Please see the attached pdf for how SERDES IP is configured.signal FL_Clk : std_logic;
signal FL_Channel0 : std_logic_vector(6 downto 0) := (others => '0');
signal FL_Channel1 : std_logic_vector(6 downto 0) := (others => '0');
signal FL_Channel2 : std_logic_vector(6 downto 0) := (others => '0');
signal FL_Channel3 : std_logic_vector(6 downto 0) := (others => '0');
signal LVDSOut : std_logic_vector(4 downto 0) := (others => '0'); -- LVDSOut(3 downto 0) = Channel 0..3 LVDSOut(4) = Clock
i0_Serdes : SERDES port map (
tx_in => FL_Channel3 & FL_Channel2 & FL_Channel1 & FL_Channel0, -- tx_in.export
tx_out => LVDSOut(3 downto 0), -- tx_out.export
tx_outclock => LVDSOut(4), -- tx_outclock.export
inclock => Clk_125mhz, -- inclock.export
--pll_areset => Reset, -- pll_areset.export
pll_areset => Reset_flu,
pll_locked => open, -- pll_locked.export
tx_coreclock => FL_Clk -- tx_coreclock.export
-- Output
g_out: for i in 0 to 4 generate
i_out: diff_out
port map(
din => LVDSOut(i downto i),
pad_out => localdisplay_dp(i downto i),
pad_out_b => localdisplay_dn(i downto i)
end generate;
Hi softwind555,
Mind share further on what is the failure observation? Just wonder if you observe the failure in simulation or hardware? - Altera_Forum
A further quesiton: Do all LVDS pins on Arria-10 support the serdes option?
