11 years agoLVDS SERDES doesn't work
I'm using Arria-10 to make a LVDS SERDES. But it doesn't work. Looking forward to your help. The code is as below. Please see the attached pdf for how SERDES IP is configured. signal FL_Cl...
9 years ago --- Quote Start --- The transmitter model doesn't work at all. I tryed thee most simple model with internal PLL. I can see that the internal PLL is locked but nothig comes out. The receiver works fine. César --- Quote End --- I´m having some problem with the transmitter too, I'm not using the receiver. I'm getting nothing as result in my data output from the TX when I look at the signalTap, I already tried with external PLL option and without it, did u find any solutions for the transmitter? I configured the output pins using the HSMC, but got no response.
