11 years agoLVDS SERDES doesn't work
I'm using Arria-10 to make a LVDS SERDES. But it doesn't work. Looking forward to your help. The code is as below. Please see the attached pdf for how SERDES IP is configured. signal FL_Cl...
11 years ago --- Quote Start --- Hi softwind555, Mind share further on what is the failure observation? Just wonder if you observe the failure in simulation or hardware? --- Quote End --- I'm using the scope to capture the clock output on "localdisplay_dp(4)" pin. But, i get nothing on it. I'm expecting a 33MHZ clock on this pin.
