14 years agoLVDS pins next to a 2.5 volt pins
Greeting, I am getting an error telling me I cannot put an LVDS pin next to a 2.5 volt pin that will be responsible for and fault LED blinking. Is there any way to get around this or is there a way t...
14 years agoIf you do not need to drive the LVDS signal during trouble shoting you can always reconfigure the LVDS pins to normal single ended inputs.
It is recomended to allways run the pin placement through the QuartusII tools before setting the PCB. There are many constraints on which pin a signal can be placed on. /Henrik
