14 years agoLVDS and single ended i/o
I need to connect a 16 bits lvds DAC to a FPGA. The FPGA is a EP3C40Q240C8N. It's possible, the FPGA have enought i/o lvds pins, but the i/o lvds pins are located on many banks. As result that it's impossible to connect an other component like a 16 bits adc (3.3V parallel bus datas) because only 1 tension level per bank is possible, many i/o pins are unavailable . It's right ? Have I others solutions that use a FPGA with more pins ? Thank2 Replies
The parallel 16 bits dac is the dac5681z by Texas Instruments :
The adc outputs levels are 0-2.5V or 0-3.3V. If I can't mixed lvds and single i/o I must use an other FPGA. - Altera_Forum
That's a good question, I'm wondering if you can feed the parallel 16bit adc with 2.5 V ? can you check the High and Low voltages limits for the adc ?
But the other constraints are that neighboring non-LVDS-PIO or PIOs on the same bank might disturb the LVDS lines. http://www.altera.com/literature/an/an466.pdf http://www.altera.com/literature/an/an479.pdf Hope someone can give you a clearer answer...
