15 years ago
LUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total sum(values*weights)< threshold and correct the weights in order to sum(values*weights)>=threshold.I think that i have to store the weights on a look up table and change the values in order to sum(values*weights)>=threshold.How i can do this?.My code is :
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_SIGNED.ALL;
ENTITY ANN IS
GENERIC ( m : INTEGER := 4; -- Number of inputs or weights
b : INTEGER := 8); --Number of bits per input or weight
PORT ( x1,x2,x3,x4: IN UNSIGNED(b-1 DOWNTO 0);
w : IN UNSIGNED(b-1 DOWNTO 0);
clk: IN STD_LOGIC;
y : buffer UNSIGNED(2*b-1 DOWNTO 0);
END ANN;
ARCHITECTURE NEURAL OF ANN IS
TYPE weights IS ARRAY (1 TO m) OF UNSIGNED(b-1 DOWNTO 0);
TYPE inputs IS ARRAY (1 TO m) OF UNSIGNED(b-1 DOWNTO 0);
BEGIN
PROCESS(clk,w,x1,x2,x3,x4)
VARIABLE weight : weights;
VARIABLE input : inputs;
VARIABLE prod,acc : UNSIGNED(2*b-1 DOWNTO 0);
VARIABLE sub : UNSIGNED(2*b-1 DOWNTO 0);
BEGIN
IF (clk'EVENT AND CLK='1') THEN
weight:=w&weight(1 TO m-1);
END IF;
input(1):=x1;
input(2):=x2;
input(3):=x3;
input(4):=x4;
acc:=(OTHERS=>'0');
FOR j IN 1 TO m LOOP
prod:=input(j)*weight(j);
acc:=acc+prod;
END LOOP;
y<=acc;
END IF;
END PROCESS;
END NEURAL;
