16 years agoLpm_mult mega function in modelsim, Help !!!!
Hi, ....... I have a single desing that multiplies 2 numbers , I'm using the lpm_mult component (from megawizard tool included in quartus), but now I want to use this design in other computer without quartus,, it has only modelsim installed, the question is: What files I have to copy to my pc with modelsim and in this manner simulate my design ??
Thanks !!!!!!!3 Replies
Yes....., I converted to vhdl my design, and there is a component named mult (connected to input and output ports), this component has her own vhdl file named mult.vhd, inside this file is :
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.all; library work; use work.pack.all; ENTITY mult IS PORT ( dataa : IN STD_LOGIC_VECTOR (ancho_ext-1 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (ancho_ext-1 DOWNTO 0); result : OUT STD_LOGIC_VECTOR ((ancho_ext*2)-1 DOWNTO 0) ); END mult; ARCHITECTURE SYN OF mult IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR ( (ancho_ext*2)-1 DOWNTO 0); COMPONENT lpm_mult GENERIC ( lpm_hint : STRING; lpm_representation : STRING; lpm_type : STRING; lpm_widtha : NATURAL; lpm_widthb : NATURAL; lpm_widthp : NATURAL ); PORT ( dataa : IN STD_LOGIC_VECTOR (ancho_ext-1 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (ancho_ext-1 DOWNTO 0); result : OUT STD_LOGIC_VECTOR ((ancho_ext*2)-1 DOWNTO 0) ); END COMPONENT; BEGIN result <= sub_wire0((ancho_ext*2)-1 DOWNTO 0); lpm_mult_component : lpm_mult GENERIC MAP ( lpm_hint => "MAXIMIZE_SPEED=5", lpm_representation => "UNSIGNED", lpm_type => "LPM_MULT", lpm_widtha => ancho_ext, lpm_widthb => ancho_ext, lpm_widthp => ancho_ext*2 ) PORT MAP ( dataa => dataa, datab => datab, result => sub_wire0 ); END SYN; We can see other component named lpm_mult.... the problem here is to find the vhdl file for this component and use it in modelsim..... - Altera_Forum
i think this is all that's required to simulate lpm functions:
--- Quote Start --- The altera_mf_components.vhd and altera_mf.vhd model files should be compiled into the altera_mf library. The 220pack.vhd and 220model.vhd model files should be compiled into the lpm library. --- Quote End --- the files can be found in $QUARTUS_ROOTDIR/eda/sim_lib reference: ModelSim Support section of QII Handbook, page 6: http://www.altera.com/literature/hb/qts/qts_qii53001.pdf - Altera_Forum
You shoud use the verilog/VHDL file for the LPM_MULT and the Verilog/VHDL file for the whole design.
The last file can be created running File -> Create/Update -> HDL from current file. Better to have everything in a single language (Verilog or VHDL). I don't know if you also need Altera libraries. Probably you don't need them for a functional simulation.
