15 years agolpm_counter, difference between sload and sset?
Hi everybody
I have to implement the lpm_counter and i do not quite get the difference between the sload and the sset signal. As I unterstood, the former sets the counter to the value of the load signal, whereas the latter sets the counter to the value specified in the LPM_SVALUE parameter. This would mean that both is the same except for the load value source. Please clarify. Thanks1 Reply
You are right set means set to ones (or zeros) or svalue
load means load the data (data is additional port) clear is same as set to zeros !
