16 years agoLow voltage for output from Cyclone III starter kit
Hello, I am looking for some advice - hopefully i have made a schoolboy error. I have a problem with an output from a cyclone III starter kit. I have written a very basic block of cod...
16 years ago --- Quote Start --- Hello, I am looking for some advice - hopefully i have made a schoolboy error. I have a problem with an output from a cyclone III starter kit. I have written a very basic block of code in VHDL to send the clock from the board directly to one of the outputs:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
ENTITY hsmc_test IS
PORT ( input : IN STD_LOGIC;
hsmc : OUT STD_LOGIC);
END hsmc_test;
ARCHITECTURE behav OF hsmc_test IS
BEGIN
hsmc <= input;
END behav; In the pin planner i have tried several settings for the IO standard inlcuding: 3.0V LVCMOS, 3.0V LV TTL etc. The problem is that the output is only being driven to about 700mV peak to peak. I am using Quartus II version 8.0. I origionally had a more complicated VHDL function which was working in simulation but not in hardware. The external hardware i am trying to drive requires the clock from the FPGA to have a minimum 2.5V for logic high, therefore i assume that this is the reason i had a problem. I would be grateful for any assistance. Thanks in advance. Regards Ade --- Quote End --- With the 700mV comment, what power supply are you useing, how are the grounds connected? With some development board they are powered via a bridge rectifer that can cause an issue if the 0V of the supply is referenced to GND. What waveform do you see and could you post it somewhere? Also what is the frequency you are looking at, sampleing frequency of the scope and have you got it set to 1M instead of 50 ohms? Thanks
