16 years agoloop must end 5000 iteration error
i have a verilog program ,while compiling it gives error like loop must end in 5000 iteration on line 36 module memory (mem_dump, ntb_encoder, enable_m, nr_w_m, addr_m...
12 years ago --- Quote Start --- Hi, Assignment -> Settings -> Analysis&Synthesis -> More Settings ... -> Iteration limit for constant Verilog loops --- Quote End --- THANK YOU!! This is exactly what I needed! What I find curious is that the default iteration limit of 5000 only allows you to loop 4999 times rather than 5000 times like you would think. I had to loop exactly 5000 times so I had to set the limit to 5001. Seems like a simple fence-post programming error in the Quartus tool. Not a big deal though. I'm just glad they let you change the limit. :)
