16 years agoloop must end 5000 iteration error
i have a verilog program ,while compiling it gives error like loop must end in 5000 iteration on line 36 module memory (mem_dump, ntb_encoder, enable_m, nr_w_m, addr_m...
16 years ago --- Quote Start --- Hi, which tool do you use ? Is a simulation your intention ? Kind regards GPK --- Quote End --- Hi, in case of Quartus the default limit for constant verilog loops is 5000. You can change the setting under : Assignment -> Settings -> Analysis&Synthesis -> More Settings ... -> Iteration limit for constant Verilog loops With your large loops I would expect a long runtime for "Analysis & Synthesis". Kind regards GPK
