16 years agoloop must end 5000 iteration error
i have a verilog program ,while compiling it gives error like loop must end in 5000 iteration on line 36 module memory (mem_dump, ntb_encoder, enable_m, nr_w_m, addr_m...
16 years ago --- Quote Start --- i have a verilog program ,while compiling it gives error like loop must end in 5000 iteration on line 36 module memory (mem_dump, ntb_encoder, enable_m, nr_w_m, addr_m, din_m, dout_m); input mem_dump; input ntb_encoder; input enable_m; input nr_w_m; input [16:0] addr_m; input [7:0] din_m; output [7:0]dout_m; reg [7:0] mem[0:131071]; reg [7:0] dout_m; reg mem_dump_bit; integer i; integer p; integer k; integer handle1; integer handle2; integer handle3; integer j; integer l; initial begin: ram_initialization_block begin p=131072; for (i=0; i<p; i=i+1) mem[i]= 8'd0; $readmemh("ref_frame.txt", mem,0,25343); $readmemh("cur_frame.txt", mem,25344,50687); mem_dump_bit = 1'b0; end end always@(ntb_encoder or nr_w_m or enable_m or din_m or addr_m or mem_dump) begin: memory_block if (enable_m == 1'b0) dout_m = 8'bZZZZZZZZ; else if (enable_m == 1'b1 && nr_w_m == 1'b0 && ntb_encoder == 1'b1) dout_m = mem[addr_m]; else if (enable_m == 1'b1 && nr_w_m == 1'b1 && ntb_encoder == 1'b1 && addr_m >= 50688) mem[addr_m] = din_m; else dout_m = 8'bZZZZZZZZ; if (mem_dump == 1'b1 && mem_dump_bit == 1'b0) begin handle1=$fopen("vertical_mv_bitstream.txt"); for (k=52272; k<53856; k=k+1) $fdisplay(handle1,"%d",mem[k]); $fclose(handle1); handle2=$fopen("horizontal_mv_bitstream.txt"); for (j=50688; j<52272; j=j+1) $fdisplay(handle2,"%d",mem[j]); $fclose(handle2); handle3=$fopen("res_bitstream.txt"); for (l=53856; l<79200; l=l+1) $fdisplay(handle3,"%d",mem[l]); $fclose(handle3); end end endmodule please any one help --- Quote End --- Hi, which tool do you use ? Is a simulation your intention ? Kind regards GPK
