11 years agoLooking for state machine in verilog
Hello there, I'm running into the problem that I don't know how to do this. I want to write state machine to run 2 conditions on my project. When I turn on machine, I want it runs 1st cond...
11 years ago --- Quote Start --- Yes it does, and Im sure its how many started, but you can easily fall into the latch trap. As I understand the 2 process state machine is a throwback to very old compilers that could only cope with registers and logic in separate processes. But this hasnt been the case for a long time. For anyone starting, I would always recommend a single process (it reads better in my mind too - more like software!) To the OP - AFAIK, the same problems can also happen in verilog. So get googling. --- Quote End --- Thank you folks. Could you point me to the sample? So I want to know the idea how this works. Best, Sean
