17 years ago
Logic error? Code error?
Hello people,
So this is my problem. I am designing a module which is basically reading from a device. Now, depending on the inputs to this module, it access different parts of the device.
if rtc_state = s0 then
	if hmi_en = '1' then
		if hmi_rdwr = '1' then
			rtc_state <= sHMI_rd;
			buff_hmi_addr <= hmi_addr;
		else
			rtc_state <= sHMI_wr;
			buff_hmi_data <= hmi_data;
		end if;
	elsif rd_wr = '0' then
		rtc_state <= sWr;
		buff_addr <= addr;
		buff_data <= data;
		flag_wr <= '1';
	elsif rd_wr = '1' and SQW = '1' and U_EN = '1' then
		rtc_state <= s1;
	else
	        rtc_state <= s0;
	end if;
end if;
Well, i've narrowed down the problem to this piece of code. Actually, i get a warning that signals dependent on the signal hmi_en are stuck to ground. Also, if i change the statement
to
if hmi_en = '0' then
then all the other states become redundant because the damn thing seems to be stuck to GND.
Note: hmi_en is an input which is coming from port.
Any/All help is appreciated.
Thanks & Regards,
Yash
    --- Quote Start ---
    Hello people,
    		else
    		end if;
    		rtc_state <= sWr;
    		buff_addr <= addr;
    		buff_data <= data;
    		flag_wr <= '1';
    		rtc_state <= s1;
    	else
    	        rtc_state <= s0;
    	end if;
    end if;
    to
    Thanks & Regards,
    Yash
    --- Quote End ---
    Hi ,
    maybe it is a stupid question, but do check that the signal hmi_en is really connected to the port ? No type mismatch ? Be aware that Verilog is case sensitive.
    The code itself seems ok but...
    First: the signal hmi_en seems stuck to '0' and is never '1'.
    Second:You are not following a standard state machine template, assuming you are doing a state machine.
    Kaz
