17 years agoLogic error? Code error?
Hello people, So this is my problem. I am designing a module which is basically reading from a device. Now, depending on the inputs to this module, it access different parts of ...
17 years ago --- Quote Start --- Hello people, So this is my problem. I am designing a module which is basically reading from a device. Now, depending on the inputs to this module, it access different parts of the device.
if rtc_state = s0 then
if hmi_en = '1' then
if hmi_rdwr = '1' then
rtc_state <= sHMI_rd;
buff_hmi_addr <= hmi_addr;
else
rtc_state <= sHMI_wr;
buff_hmi_data <= hmi_data;
end if;
elsif rd_wr = '0' then
rtc_state <= sWr;
buff_addr <= addr;
buff_data <= data;
flag_wr <= '1';
elsif rd_wr = '1' and SQW = '1' and U_EN = '1' then
rtc_state <= s1;
else
rtc_state <= s0;
end if;
end if; Well, i've narrowed down the problem to this piece of code. Actually, i get a warning that signals dependent on the signal hmi_en are stuck to ground. Also, if i change the statement if hmi_en = '1' then to if hmi_en = '0' then then all the other states become redundant because the damn thing seems to be stuck to GND. Note: hmi_en is an input which is coming from port. Any/All help is appreciated. Thanks & Regards, Yash --- Quote End --- Hi , maybe it is a stupid question, but do check that the signal hmi_en is really connected to the port ? No type mismatch ? Be aware that Verilog is case sensitive.
