Clay's avatar
Clay
8 years ago
Log file of USB Blaster
Hello Team,
I want to program an MAX 10 FPGA : 10M04SCU169A7G
I can use command line to execute programming process.(D:\altera\15.0\quartus\bin64\quartus_pgm -i -c USB-Blaster -m JTAG -o P;)
Is there any log file I can check for programming result?
Programming Device : USB Blaster program MAX 10 IC
Platform: Windows 7 , quartus_pgm 15.0
Thank you for any advice you can provide.
  • Clay's avatar
    Clay
    These information are useful.
    Thank you all.
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Hi Clay,
    We can verify the programming by
    • Generate the Assembler report using <designtop>.asm.rpt
    • Program file using quartus_pgm -m JTAG -o P;<designtop>.sof --verify we will get the checksum in command line.
    • Now we compare the checksum in command line and Assembler report.
    Hope it helps.
    Anand Raj Shankar
  • Clay's avatar
    Clay
    Thank you for the information.
    I wonder is there any readable text file to make the process traceable?
  • vj123's avatar
    vj123
    There is a message window/log in the Quartus tool that should be showing the programming process. Refer to the screens shot.
    After full compilation .sof programming will generate under out_files directory.
    Best Regards
    Vikas Jathar
