DinhLe
1 year agolocal_cal_fail is assert when running DDR3 SDRAM Test by Nios II example on Sockit Rev D board
Hi, I have a problem relate to DDR3 interface when running DDR3 SDRAM Test by Nios II, local_init_done is asserted. I tried to debug and search information but there is no more information. Can you ...
tehjingy_Altera
1 year agoHi
Have you tried running the EMIF toolkit to check if the SDRAM have been set up properly?
What device are you using at the moment?
Jingyang, Teh
- DinhLe1 year ago
I am using Sockit Arrow board rev D (Terasic - SoC Platform - Cyclone - SoCKit - the Development Kit for New SoC Device) with Cyclone V(5CSXFC6D6F31C6N), DDR3 chip is IS43TR16256A (issi.com/WW/pdf/43-46TR16256A-85120AL.pdf).
I programmed the .sof file through Demonstration Batch File in SoCKit_DDR3_Nios_Test example, and problem was happened. The architecture of example is below:
I tried to run EMIF toolkit (in Quartus 13.1), the memory connection is:
The summary report:
Interface details:
DQS group masked
DQS group calibration
DQ Pins margin before, during and after calibration are 0
