14 years agoLOC Program for VHDL
Hey Guys. I've been asked to count the number of lines of code (LOC) for VHDL. I need to count the physicial lines of code, logical lines of code, and also the number of commented lines. Anyone...
14 years ago --- Quote Start --- The limited significance of LLOC measures isn't specific to VHDL. Counting executable statements gives some information about the code's complexity, it can't take account for different levels of verbosity that exist in all programming languages. --- Quote End --- Yes, valid point. The comment: --- Quote Start --- I need to count the physicial lines of code, logical lines of code --- Quote End --- led me to write the two code snippets of identical code, as I think this is an example of the type of code that has a different number of physical lines than logic lines. In this case, could he count the number of lines in the RTL code generated by Quartus after synthesis? Probably not, since there is often a lot of redundant connections in the Altera code (where signals are simply renamed). Cheers, Dave
