JBenj
8 years agoLoad from EPCQ fail
I have a Cyclone V FPGA connected to an EPCQ128 as depicted in the standard configuration for the device. I am able to load the .jic file and the .sof file but whenever I kill power to my board and r...
JBenj
8 years agoNoorani,
The STATUS pin is high, CONFIG DONE is low, CONFIG is high. It does appear that there is a reset with the programming and the STAUS pin does go from low to high. It also appears that DATA0 begins transmitting slightly before the CSO goes low in certain instances.
