JBenj
8 years agoLoad from EPCQ fail
I have a Cyclone V FPGA connected to an EPCQ128 as depicted in the standard configuration for the device. I am able to load the .jic file and the .sof file but whenever I kill power to my board and r...
Nooraini_Y_Intel
8 years agoHi,
Did you scope the nCONFIG, nSTATUS and CONF_DONE signal when power up? Is the nSTATUS signal stay high all the time after nCONFIG goes high? Or did the nSTATUS signal toggle? Is the CONF_DONE signal is directly pull up to the VCCPGM via 10kohm? If you have any other component such as LED or external host connecting to the CONF_DONE, remove those component. Potentially these extra component can hold the CONF_DONE low. Ensure the CONF_DONE signal is connected to VCCPMG via 10kohm pull up.
Nooraini
