12 years agoLink to SRAM Qsys Tutorial 8 Bit sought
Hmm like many others I'm stunned at how difficult it is to add an SRAM component to a NIOS system. Two days and so far all I can get is a mishmash of signals that seem to bear no relation to...
12 years agoare these warnings significant:
Info (12130): Elaborated megafunction instantiation "LPM_BUSTRI:inst24" Info (12133): Instantiated megafunction "LPM_BUSTRI:inst24" with the following parameter: Info (12134): Parameter "LPM_WIDTH" = "8" Warning (12000): Port "tristate_conduit_bridge_0_out_tcm_byteenable_n_out" in macrofunction "inst" has no range declared,the Quartus II software will connect the port to pin "tristate_conduit_bridge_0_out_tcm_byteenable_n_out[0]" because the pin is a member of a single bit bus with the same name as the port Warning (12000): Port "tristate_conduit_bridge_0_out_tcm_chipselect_n_out" in macrofunction "inst" has no range declared,the Quartus II software will connect the port to pin "tristate_conduit_bridge_0_out_tcm_chipselect_n_out[0]" because the pin is a member of a single bit bus with the same name as the port Warning (12000): Port "tristate_conduit_bridge_0_out_tcm_outputenable_n_out" in macrofunction "inst" has no range declared,the Quartus II software will connect the port to pin "tristate_conduit_bridge_0_out_tcm_outputenable_n_out[0]" because the pin is a member of a single bit bus with the same name as the port Warning (12000): Port "tristate_conduit_bridge_0_out_tcm_read_n_out" in macrofunction "inst" has no range declared,the Quartus II software will connect the port to pin "tristate_conduit_bridge_0_out_tcm_read_n_out[0]" because the pin is a member of a single bit bus with the same name as the port Warning (12000): Port "tristate_conduit_bridge_0_out_tcm_write_n_out" in macrofunction "inst" has no range declared,the Quartus II software will connect the port to pin "tristate_conduit_bridge_0_out_tcm_write_n_out[0]" because the pin is a member of a single bit bus with the same name as the port Warning (12241): 4 hierarchies have connectivity warnings - see the Connectivity Checks report folder Info (13000): Registers with preset signals will power-up high Info (13003): DEV_CLRn pin will set, and not reset, register with preset signal due to NOT Gate Push-Back
