12 years agoLink to SRAM Qsys Tutorial 8 Bit sought
Hmm like many others I'm stunned at how difficult it is to add an SRAM component to a NIOS system. Two days and so far all I can get is a mishmash of signals that seem to bear no relation to...
12 years agoAn Update - please if anyone has any extra information - I am really trying hard here but no joy.
I have tried three different methods each with the same (or similar) result - Address lines working away fine when running a small test C program writing to the correct memory locations. But no data writes occurring. No activity on the Tristate Data bus lines. Here are the images from two of the attempts I have made - one using the Generic Tri contrller and the other using a VHDL with Avalon Slave. At present I do not have a ram chip installed I just want to see the data lines move on my scope. I haven't put the instruction line onto the RAM for this reason - and so I'm running the etst program from internal ram. Any ideas welcome. Am I running into problems because I have this all in a schematic whereas most examples seem to stop at the system level? Can I test the ram lines using the COmmand console without having a ram installed?
