10 years agoLE and memory blocks in a cyclone
I'm quite new in the world of the FPGA, indeed, I'm an engineer student in end-of-studies internship which is about using a FPGA. Well, I'm telling you that because I guess that you will think my question is a question of newbies :oops:. When I start studying FPGA, my teachers said that the most important characteristic of these devices is the number of Logic Elements. But during my internship, I did some architectures using IP and then, after a full compilation, I realized that the characteristic which constrained me the most is the "total memories bits". After few research, I understood this characteristic was the representation of the memories blocks (like M9K). Here come my question, what is the constitution of a memory block? is-it a very important parameter in a fpga? Example: My FPGA have 600K memories bits and 22K LE. After Quartus compilation, I realize that my architecture need 500K memories bits but only 2K LE. can i use le instead of memories block for 1 or 2 ip? I hope that I explained my problem clearly, Thank in advance, Clément.
