10 years ago
LE and memory blocks in a cyclone
I'm quite new in the world of the FPGA, indeed, I'm an engineer student in end-of-studies internship which is about using a FPGA.
Well, I'm telling you that because I guess that you will think my question is a question of newbies :oops:.
When I start studying FPGA, my teachers said that the most important characteristic of these devices is the number of Logic Elements.
But during my internship, I did some architectures using IP and then, after a full compilation, I realized that the characteristic which constrained me the most is the "total memories bits".
After few research, I understood this characteristic was the representation of the memories blocks (like M9K).
Here come my question, what is the constitution of a memory block? is-it a very important parameter in a fpga?
Example:
My FPGA have 600K memories bits and 22K LE.
After Quartus compilation, I realize that my architecture need 500K memories bits but only 2K LE.
can i use le instead of memories block for 1 or 2 ip?
I hope that I explained my problem clearly,
Thank in advance,
Clément.
