19 years agoLCD TV Becomes Bulletin Board good or bad idea?
Do you see any reason this wouldn't work well? I am planning to build an FPGA device with VGA out and SD card input, this would simply display slide after slide on the TV with upcoming events, who ha...
19 years agoI'd consider the still images to be a true hassle in the longer run. I'd want to have some online connection and be it just over the serial line to a PC. The need to insert a memory card limits the range of possible locations to manually reachable locations. With just a serial port the content can be updated remotely. Meaning, add a PIC or an AVR for the slave serial port. It'll add a worthwhile two dollars to the cost.
Rene
