11 years agolaunch signal tap thru command line
I'm trying to open the siganl tap using the command line but fails. I've found this link: http://www.alteraforum.com/forum/showthread.php?t=40821 and tried using this command only: open_session -name stp1.stpI've put it in a tcl file and ran it in the command line using: quartus_stp -t launch_stp.tcl
It does not work. When I run it, I get the following error, saying 'can't open signaltap II file for reading. Make sure the signaltap II file exists and has read permission". Well, I checked, and the file do exists and has permission as any regular file. I've found this error documented here: http://drlnet.dyndns.org/help/quartus/webhelp/mergedprojects/tafs/tafs/tcl_pkg_stp_ver_1.0_cmd_open_session.htm But nothing special is said regarding that. Any idea how to invoke the signal tap sw? btw, I'm using version 10.1. Thx.
1 Reply
Did you navigate to the correct directory? I would normally run it like this:
C:\Altera\quartus\bin\quartus_stp -t D:\test\test.tcl
