11 years agolaunch signal tap thru command line
Hi, I'm trying to open the siganl tap using the command line but fails. I've found this link: http://www.alteraforum.com/forum/showthread.php?t=40821 and tried using this command only: ...
11 years agoDid you navigate to the correct directory? I would normally run it like this:
C:\Altera\quartus\bin\quartus_stp -t D:\test\test.tcl
