Andrey_P
4 years agoLatency of rdreq to q[] in DCFIFO
In the FIFO User guide I see the following in Table 7:
Output latency of rdreq to q[] : 1 rdlck.
At the same time, on Figure 3 ( Functional Timing for the rdreq Signal and the rdempty Signal ),...
- 4 years ago
Andrey,
Thanks for you input. This probably related to documentation spec bug which I will file for fix. Seem there is discrepancy between spec and diagram 3.
