14 years agoLatch Inferrence
Hey guys,
Lets say you have a simple state machine output assignment block like the one below:
always @(pstate)
begin
case(pstate)
s0:
begin
out1<=0;
out2<=1;
end
s1:
begin
out1<=1;
out2<=0;
end
default:
begin
out1<=0;
out2<=0;
end
endcase
end
When you compile the above code, you get infered latches for the outputs, which are bad. How can I get around this? I don't want to use simple assign statements for the outputs, because the idea is to keep the value of a signal until a different state arrives. For example, if I am in state 0, I want out2 to remain high until s1 is reached. Of course, this requires memory. But I don't want to infer latches. And if I use a posedge clock in the sensitivity list, I get unexpected results. Any ideas would be greatly appreciated.3 Replies
This is a address I think it will help you!
http://www.alterawiki.com/w/index.php?title=special%3asearch&search=+state+machine&go=go - Altera_Forum
In the present case, no latches are inferred. You get latches, if the variables are not assigned in all branches of the case construct.
Yes in this code you cant get a latch...
