12 years agolan91c111 autonegation
Hi First let me start by describing the hardware that I am using. I am using the SMSC LAN91C111 ethernet MAC & PHY which is driven by the NIOS II processor . I am not using a EEPROM in ...
12 years agoI noticed under your "FOR autonegation" section, there's a line that reads "the value of autonegation reg capable is 0". Is that local or remote end capability register? Do you have a scope? Can you verify if your sending FLPs if autonegotiation is enabled or MLT3 if you enabled 100MB. If aneg is enabled, can you break the link, verify with a scope you see FLPs, reattach the link, and see if it transitions from sending FLPs to MLT3/idle? Just for grins, have you tried enabling any loopbacks (client or line side) to verify communication?
