12 years agolan91c111 autonegation
Hi First let me start by describing the hardware that I am using. I am using the SMSC LAN91C111 ethernet MAC & PHY which is driven by the NIOS II processor . I am not using a EEPROM in ...
12 years agoHI
i have tried by disabling the autonegation mode,i have forced to 100 mbs,still the link is no up, i am able to read the advertise register ,the below is the message what i have got while running in autonegation and 100 mbs mode. FOR autonegation Starting initalization OS Start Initializing network dev InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. Your Ethernet MAC address is 00:01:02:03:04:05 prepped 1 interface, initializing... Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) the value of status reg is 7809 the value of autonegation reg is 1e1 the value of autonegation reg capable is 0 the value of ack is 20 smsc91c111 Auto-negotiation: ERROR; timed out SMSC ethernet Rev: 0x3392, ram: 8192 mctest init called IP address of et1 : 192.168.1.100 DHCP timed out, going back to default IP address(es) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) FOR 100 MBPS OS Start Initializing network dev InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. Your Ethernet MAC address is 00:01:02:03:04:05 prepped 1 interface, initializing... Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) 100 Mbps, Half Duplex SMSC ethernet Rev: 0x3392, ram: 8192 mctest init called IP address of et1 : 192.168.1.100 DHCP timed out, going back to default IP address(es) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4)
