14 years agoJTAG UART slowness
Hi All, I am trying to write a file from the PC into SDRAM through the JTAG UART, and have found that it is quite slow. I only see about 1KB/s, and need to transfer files that are about 10-20...
14 years ago --- Quote Start --- I took dwh's suggestion and used the JTAG to Avalon MM Bridge instead of the NIOS, and used the write_master_memory command which speeded things up significantly. I now see ~100KB/sec which is good enough for my purposes. --- Quote End --- Great! Cheers, Dave
