11 years agoJTAG Tolerence for MAX5 Device 5M2210Z
I am using Max5 5M2210Z device in one of my projects. In this I am configuring Bank1 voltage level as 1.8V. Since JTAG is also going to the bank1, the JTAG level should be 1.8V too. I want to...
11 years agoLook at the dc and switching characteristics for max v devices' 'dc and switching characteristics for max v devices (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-v/mv51003.pdf) for Max V. Yes the pins will tolerate 3.3V. However, if you're operating a bank at 1.8V the recommended max level is 1.89V. Persistent over-driving of a pin could result in damage - eventually.
However, what is your BMC (?) going to make of the 1.8V TDO signal driven towards it? It's expecting a 3.3V logic levels, probably with a minimum V_high threshold of 2.2 to 2.5V. What's it going to make of a 1.8V logic high? My suggestion - use level translators. Cheers, Alex
